주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
질문 마감됨
Home button not working
Hi,
I bought a pink iPhone 5c on eBay with a smashed, non working screen . The seller has removed FindMyPhone for me but couldn't remember her old passcode at the time.
After replacing the damaged screen, I found I could not do a restore in itunes as the home button isn't letting me go into recovery or DFU mode.
I have the lastest iTunes on my Windows 10 PC. I read somewhere online that all the 10 passcode attempts have to be used up in order to use restore in iTunes (on a PC the phone doesn't know) so I used them. I now have 'iPhone Disabled, connect to iTunes' only.
I swapped the logic boards today. The pink Disabled iPhone is the one with the iTunes 'recovery' home button problem and I have a green iPhone 5c which just has a 'no service' issue but a working home button.
The pink phone now with the green 'no service' logic board has a working home button so it's not the pink's home button contacts.
The green phone with the pink Disabled logic board still has a home button issue.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I can't get it into recovery mode with Reiboot either.
댓글 달기
답변 1개
가장 유용한 답변
the homebutton is connected to the dock connector, try swapping them
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 265
