주요 콘텐츠로 건너뛰기
모델 A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 또는 2.8 GHz Core i7 프로세서
432 질문 전체 보기
iMac 21" Power Button issue
How do I change the power button of my iMac 21" My iMac has a power button problem. I have to keep pressing it until it starts.
I think it is an issue with the Button from the first day. It's a 2010-2011 model.
Does Apple have an out of warranty solution for this? Personally, I think the power button should be replaced. How to do this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Hi There
I had same problem, but a little heat to the back around the Power Button will loosen the glue which will allow you to remove the power button assembly for easy soldering.
댓글 달기
답변 1개
선택된 답변
You may have a logic board or power supply problem. The power switch is a soft switch design. It uses a low voltage logic to then fire off a relay on the power supply which then turns on the computer.
If you are able to use a multimeter you could take a measure of the switch to see if its working and you can also check the rest of the circuit. Follow this IFIXIT guide: iMac Intel 21.5" EMC 2428 Logic Board Replacement. Jump down to Step 22 and locate the Purple marked connectors. The lower one is the power switch.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
docinix 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 6,140
