주요 콘텐츠로 건너뛰기
Magic 트랙패드 수리 안내서.
25 질문 전체 보기
battery acid damaged batt-compartment - how to restore?
Hi together,
I own a Apple Magic Trackpad, where the batteries ran out and damaged the battery compartment.
I removed the batteries and cleaned the battery compartment. Now, the batteries have a little bit axial play (2mm?), so I have to put some metal spacer in between. And the Trackpad is only working sporadically, I suggest a bad contact problem.
When I look into the battery compartment, I only see a elastic radial spacer and a (always corroding) center contact.
Does someone has any suggestion, how to resurrect the trackpad? Is there any part missing in the battery compartment? A spring maybe?
Pic of contact
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Try using a Q-tip and some isopropyl alcohol (no contact cleaner) and or a toothbrush to scrub it away.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
kaufschorsch 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 209
