주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
How to add a new frame to iPhone lcd assembly?
So I am trying to refurbish screens my removing broken glass from an lcd and then replacing the glass using loca glue and everything and that has been going well, but the new issue is that I don't know how to apply the new frame. I am buying brand new frames from mentor.com but it's just not working out for me because I try using the double sided tape but that's super difficult to align and it doesn't work good at all. I tried using adhesive tape but that's even worse. I've done a few with super glue but that is just a risk because a lot of the time the glue squeezes out of the frame and makes the screen look like garbage considering I have t scrape it off so I have a working screen, but I can't sell it because it doesn't look new at all. If anyone has experience and knows what I can do please let me know. Thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
First of all, I'm pretty sure you need to be using OCA glue. I've never bothered to do these low rent things, because I've always been concerned about quality. But, I also believe you can get a frame, that holds all these things into place, while you're gluing them together. So you can consistently grind them out
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
You need using hot metal glue, but need the frame machine to heat and pressure the frame on the glass
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mathew 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 96
