주요 콘텐츠로 건너뛰기
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299 질문 전체 보기
wifi button greyed out on ipad air after update
Hi, i recently updated my ipad air to ios 9.1 i think and now i have a greyed out wifi button and no bluetooth, i have find my iphone turned on so i cant restore it because it needs a wifi signal to turn off find my iphone, any ideas??
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Update.. restored this ipad multiple times and set it up as a new ipad but still no luck. I own a device repair shop so knew about the greyed out wifi switch issue that plagues some of the iphone 4s and know how to fix that so tried the same fix but no luck. Contacted apple support on a chat forum as the ipad is 6 months out of warranty and they wanted €330 to carry out an out of warranty repair but as soon as i mentioned that this has all the same symptoms as the 4s issue they set up a call-back from someone from the senior team that aggreed to repair/replace the ipad for free.. happy days
댓글 달기
답변 6개
가장 유용한 답변
I gave same problems, please help me, I have an iPad Air 2 on iOS 9.3.5
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I'm having the same issue, was using it at the time and all of the sudden it coudn't connect to the server. I've tried everything including a restore to factory and nothing. have you figured out a solution?
댓글 달기
I have a iPad Air 2 and same thing happened. I went into the genius bar and they refused to replace or fix the issue because it was out of warranty. They also suggested me to trade-in the iPad for a new one plus pay a couple hundred bucks! ( wtf? ) My iPad Air 2 64gb worked flawlessly before the updating to 9.3.5.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I believe you can turn off 'find my iphone' directly through the ipad: settings --> icloud --> near the bottom it'll be a slider to turn on or off find my iphone. Or at least that's the way it is in my iphone 5c
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You need a wifi or data access to turn off 'find my iPhone ' and because it's a wifi only iPad and the Bluetooth doesn't work either, I put it into dfu mode and restored it that way. It seems to a hardware issue because even after the restore its the same..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Because it happened during an update i convinced apple to replace the ipad.. even though it was out of warranty.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
wifi and bluetooth buttons are inactive. not working after upgradation ios software. Please say how to rectify my issue on ipad
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
chris 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 11,538
