주요 콘텐츠로 건너뛰기
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
331 질문 전체 보기
질문 마감됨
Why wont it charge unless I hold the cable
I have to hold my cable at the end connected to my ipod and push it so it will charge but that is a pain is there any other way to charge i have an appointment at the genius bar but i would still like to know
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Try cleaning the charge port out with a tooth brush and 99% alcohol. 9 times of out of 10 there is dirt or lint causing issues and much cheaper than a charge port replacement, always try the easy way first ;) If it still continues then you will need to seek a charge port replacement. Note that the charge port replacement on this model is not a easy repair it requires soldering and patience to not break the lcd coming out.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Its your charging port. I had the same prob and i opened it up and replaced it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 104
