주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
질문 마감됨
Update and restore loop ios 8.4.1
I have an iPhone 5c which was badly damaged and after replacing most of the parts i tried to boot it however it has the itunes and lightning cable logo, itunes recognises its there however when i press restore iphone and then restore and update it goes into a never ending loop. I have downloaded all the recommended programs and still not luck. Help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
Also forgot to mention i was in the process of doing an OTA update to 9.1 then it was interrupted and has been doing the boot loop since
Have you attempted to restore the iPhone in DFU mode?
댓글 달기
답변 1개
It sounds like you're stuck in a boot loop. One way to TEMPORARILY get out of this is to hold down the "+" volume button on your iPhone as soon as you see the apple logo appear. Keep holding the volume button! it will take longer than you would think! If this works, then plug it into you computer and restore it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 216
