Recovery of my deleted text messages
Can I get text messages that I have deleted on my phone
좋은 질문 입니까?
좋은 질문 입니까?
You can try to recover deleted text messages from Android in following two ways:
1.You can recover SMS from Android backup if you have backed up your data before.
2.If you do not have any backups. You may have to try to use some third-party recovery tool like Android Data Recovery on FORecovery, which may help you get your deleted texts back.
해당 답변은 도움이 되었습니까?
Simple steps to get back deleted sms: Connect your Samsung phone to your computer(Mac or PC), scan the lot data, preview and recover. In just a few clicks, you can restore lost sms from Samsung mobile phone.
해당 답변은 도움이 되었습니까?
How long have you deleted the text messages? It is crucial to whether you can recover them successfully or not.
If newly generated files cover the deleted messages, it will be hardly to recover.
You need to stop using the phone immediately after the deletion. Then, select a reliable tool to begin the recovery. In general, it is easy to recover the deleted text message on your own.
If you are not experienced in it, you can refer to this page: https://www.minitool.com/android-recover...
해당 답변은 도움이 되었습니까?
It is out of luck of you. I happen to know Android data recovery is specially designed to recover Android data. You can follow the steps below to restore the deleted SMS messages on your Android:
1. Download a data recovery program and connect your Android with PC via USB or WiFi
2. Start scanning and select the file which you want to restore
3. Save the recovered items
해당 답변은 도움이 되었습니까?
Maybe this “Disk Digger” thing on google play would help but i only know it only saves pictures
해당 답변은 도움이 되었습니까?
Well I will suggest you to check out the following it can help you in recovery the message: https://www.androidpolice.com/retrieve-d...
해당 답변은 도움이 되었습니까?
24 시간 전: 3
7일 전: 14
30일 전: 59
전체 시간: 4,721
댓글 2개
can recive my deleted message back
vinod vinu 의
If you don't sync your phone data to the cloud for backup, the only way to recover deleted messages on your phone is the data recovery tool.
This is the answer I got after searching: https://www.fonecope.com/recover-deleted...
lopezpez 의
