Why wont my device charge when plugged in?
when i plug in my device it does not charge why is this?
좋은 질문입니까?
좋은 질문입니까?
My device want charge at all or it want come on at all need help please......
이 답변이 도움이 되었나요?
Hello,
I am getting nothing when trying to charge my cubby. The device won't even turn on. Thanks Jeffrey_Hemingway@yahoo,com
It is possible that you don't have the adapter fully in the charging port or it is possible your charging port may need replacement. Before attempting to replace your charging port check to see if the cable & adapter will charge another device it is possible it is a faulty cord or adapter
이 답변이 도움이 되었나요?
I found a battery wire that is soldered to one of the three pads on the main board was not connected they felt tight but were being held in place by the plastic insulation. I stripped back the insulation(about 1/16 inch) and resoldered the connection
이 답변이 도움이 되었나요?
maybe its your cable not working probably, i suggest you get a new one. I reckon it won't be too pricy
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 1,727
