주요 콘텐츠로 건너뛰기
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 질문 전체 보기
No response when plugging in charger cable despite new battery.
I have an iPad Mini 2 that I've been troubleshooting and I'm afraid I have a bad dock connector. Any suggestions on how I can troubleshoot the connector?
It was having problems charging (wouldn't charge past 2-3% one day) and wouldn't stay on for more than maybe 30 seconds. I put in a new battery and everything looked good. But it won't respond at all when I plug in a cable (I tried several). No wake, no noise, no lightning bolt, and it isn't recognized when plugged into my Macbook. But it wakes fine by home button and seems to be working normally in every way except for slowly losing power.
It's starting to seem like a bad dock connector or something on the logic board but I'm hoping someone has other insights or suggestions since I'm not sure I'm ready to throw my hands up and send it to a tech just yet. Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
Seems worth noting that this is a used ipad with an aftermarket charger/cable. I'm not sure if the charger/cable could have anything to do with the problem. Everything inside the connector looks normal so far as I can tell. Everything inside the case also looks clean and original with no obvious damage.
댓글 달기
답변 1개
If it's slowly losing power that sounds pretty normal. If you're using an aftermarket charger, you should stop. Only bad things will come from this. It does sound like what you're getting at is that you need a new Lightning dock
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Brian JJ 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 141
