By pass thermostat in refrigerator
I want to by pass thermostat in the refrigerator so that it work without thermostat and which wires must i combine together.
좋은 질문 입니까?
좋은 질문 입니까?
Without a model number I won't know. I do know that a refrigerator with a PCB will be difficult. An older refrigerator with a knob that turns for tempature control will usually have a bulb going into the freezer section and only 2 wires to the control plus a ground wire. Those 2 wires connected together will bypass the control and cause the compressor to run.
해당 답변은 도움이 되었습니까?
Will thus hurt compressor if it runs
해당 답변은 도움이 되었습니까?
I think this bypass results in a continuous demand on the compressor, except for the period the defrost cycle occurs. I would not want to consider this a permanent solution, if it were my frig, and I certainly wouldn't think this would be wise when servicing someone else's appliance.
I would only bypass it temporarily to test other components. If your trying to fix your refrigerator this isn’t the way to fix it. It will cause the compressor to run all the time except in defrost. The tstat is what tells the compressor to “ turn off, it’s cold enough”. Without the tstat it will never stop. It won’t hurt the compressor by bypassing the tstat but it will run all the time and that will shorten its life.
24 시간 전: 1
7일 전: 13
30일 전: 50
전체 시간: 5,245
