주요 콘텐츠로 건너뛰기
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299 질문 전체 보기
질문 마감됨
iPad Air ran over by car, best way to replace screen?
Hi, I came across and iPad Air that appears to have been run over. It had a case on it but the digitizer and LCD are trashed. Logic board still seams to be intact cause the alarm clock on it woke me the next morning. Tried finding the owner for it but no luck. I'm wanting to fix it up for use again but I'm not sure what the best way is to remove all the glass and adhesive. Also I've been trying to find another iPad Air that has a logic board problem so I can just do a board swap seeing that most of the other components are damaged or missing. Any help would be appreciated.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Before you start working on it make sure it is not iCloud locked or else your going to waste your time and money for nothing.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I connected it up to my computer and it would only let me do a restore on it. Haven't done it yet though
댓글 달기
Check the serial number here to see if icloud lock before repairing it https://www.icloud.com/activationlock/
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 306
