주요 콘텐츠로 건너뛰기
모델 A1103 / 1.25, 1.33, 1.42, 또는 1.5 GHz G4 프로세서
62 질문 전체 보기
Can I upgrade the wireless in a PowerPC G4 Mac mini?
Want to upgrade it with a wireless card (brought use original configuration wireless was optional). Want to make sure I get the right wireless card but also get the most bang for my buck. What do you suggest?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
가장 유용한 답변
The only compatible internal wireless card is the Airport Extreme card.
If you choose to go the USB route, there are other options, but I must confess I am unfamiliar with them.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi,
I have pretty much the same problem and so far I was unable to make good use of all the usb wireless dongles. Nothing seems to work...
Cheers,
Rod
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
hi rodrigo,
you should look for an wireless dongle that is supported by your operating system or has the driver/kext for your system.
there are not that many options for you - i know that there are a few chipsets are supported by os10.
the easiest way to find something that works is the hardware list for kismac, kismac is/was a very popular wardriving program for mac computers - on their webpage are the working and not working devices for that program - if it works with kismac - it works with os 10
CLICK here
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
EndLessTinkera 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,542
