주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG에서 제작한 터치스크린 스마트폰 모델 번호 VS980는 2013년 9월에 출시되었습니다.
Screen damaged and display non-functional
My daughter's LG G2 was dropped face down and run over by an SUV. The screen and display are non-functional. The phone rings but have no way to answer to test the speaker/microphone. Is this worth even trying to fix or do I just give her my old Motorola Droid until it's time to upgrade (May 2016)?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Unfortunately there is no sure -fire way to test the components you listed with out a functional LCD and Digitizer. The fact that the phone still rings is a good sign. It means that the phone is still on, the cellular modem is functional, and the speaker works. Given the fact that the speaker connects to the mainboard via the same flex cable that the microphone is on, there is a good chance that the mic still works.
My advice is to open up the device and take a look at the components. Look for any physical damage to the mainboard or flex cables. Also, check the battery and make sure it has not begun to swell. Sudden impact to the battery such as a car running over it may cause it to begin to swell up. In my experience the G2 is pretty resilient. So, if everything looks good on the inside, go ahead and get a new screen.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Guess I'm going to give this a shot. Thanks for the input Dylan.
You're very welcome!
댓글 달기
답변을 추가하세요
tedbelales 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 16
전체 시간: 269
