주요 콘텐츠로 건너뛰기
The Inspiron 15-3521 has an optional touch screen feature and has a 15.6" display. This laptop is also complete with a matte finish and keyboard complete with number pad.
40 질문 전체 보기
Why can't I install the usb driver?
After installing windows 10 there were a couple missing drivers. I troubleshooted the laptop in devices and printers and it fixed all the driver issues except for the USB2.0-CWR driver. It says it doesn't have it. I tried to update it from device manager but it says windows can't find the driver, go to the manufacturersame website. I couldn't find it on dell.com either. What should I do?
It says in properties that the drivers for this device are not installed. (Code 28)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
have you updated windows 10 yet it could help
I'll try that thanx.
Ran a bunch of updates. Didn't change it. I had a problem on an hp pavilion recently where it didn't recognize the DVD drive. It seemed like a driver problem but was actually something in the registry that needed deleted and then it worked fine. Could this be something similar?
댓글 달기
답변 4개
선택된 답변
Hi,
Did you try this link, scroll to bottom and download Realtek USB 2.0 card reader?
http://www.driverscape.com/manufacturers.... If you have please ignore.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks, Jayeff, your link worked great.
댓글 달기
down load driver genius it should find the driver.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hey! It is easy! If you can't download drivers from official website, you can try to use a 3rd-party driver program to download driver for Windows 10. More detail: http://goo.gl/5h6ICN
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
maybe you should look for the driver Sesua, try visiting http://www.aiydriver.com and find your laptop drivers
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jesse 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 1,496
