주요 콘텐츠로 건너뛰기
Model A1224 / Mid 2007 및 Early 2008 / 2, 2.4, 또는 2.66 GHz Core 2 Duo 프로세서
538 질문 전체 보기
No Power, #1 LED Stays lit, #'s 2&3 LED's flash
I have an Intel iMac 20", Model A1224, 1gb RAM, that one day just stopped turning on. I opened it up and checked the diagnostic LED's on the board. #1 stays lit. #2 and #3 blink on and off. #4 doesn't light up at all.
When I press the power button on the back of the black, plastic case, the internal fans will attempt to spin, but will not spin. (They rotate *maybe* one (1) degree out of the 360 degrees they would spin.) I can hear a high-pitched sound--kinda like a whirring sound--coming from the power supply when this occurs.
I have attempted to reset the SMC with, seemingly, no effect.
Any advice would be much appreciated.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
I have the same exact issue. Replaced the power supply and 2&3 are still flashing. Did you find out the problem?
댓글 달기
답변 2개
선택된 해법
The blinking indicates a RAM problem. First reseat the RAM. If that fails try one stick at a time in each of the slots.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Excellent low cost suggestion. +
댓글 달기
Seems that the power supply has gone. #1 LED indicates trickle power, it's always on when the computer is plugged in and supplies 5V to the logic board. Whe #2 and#3 are blinking it means that CPU and GPU can't be initialized. Usually a (don't know the english term for it, i try ;-)) power store diode is gone on the power supply. You can check it but be careful. Leave the machine unplugged for at least 24H cause the capacitors can store a lot of voltage.
Good luck.
해당 답변은 도움이 되었습니까?
점수 1
2 댓글:
Installed a new Power Supply. #2 and #3 LED's are still blinking. Any other thoughts? Thanks.
I have the same problem. I also changed power supply and the problem still there. Any answer?
댓글 달기
귀하의 답변을 추가하세요
Plumberman010 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 3,047
