주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Where is the IMEI number of the iPhone 6 on the motherboard?
I replaced the display to a customer but after a few days the iPhone has shut down and no longer has reignited. since he was in another city he showed it to another shop who told him that the motherboard was damaged. This is impossible because the simple procedure for the replacement of the display. The customer brought me back smartphone saying it was my fault. I suspect that they stole the motherboard and put the damaged one. how do I identify the motherboard with the chassis? There is an identification number IMEI? Sorry for the English but use google. Thank you
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
i am also facing this problem.Can you help me?
댓글 달기
답변 5개
선택된 답변
Hi antoni
I would like to help you , i can give you some tips, my it can help you.
If you have the orginal imie number wich is on the back side of the phone. You can check the phone details and then you can see the memory of the phone if it is 16,64,128. Whene you find this information you have to check the flash memory on the motherboard it is on the back side in the center, there is a serial number on the chip. Give me this serial number and i will give you the iformation about this chip how much GB is spouse to be. Maybe they but mothererboard withe different GB, then you know if someone changed the m/b or not , but this only in case whene th GB not much , but also it can be the put MB with same GB ,
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
thanks for the information it's really good idea to check the flash memory chip and compere it with the phone memory
how check the chip serial number
and exactly what chip??
댓글 달기
가장 유용한 답변
I don't think it's written anywhere. If it would be, it'd be on the modem. But it sounds like you didn't record the iemi in the first place
해당 답변은 도움이 되었습니까?
점수 2
댓글 5개:
There is a way to see if your motherboard has been effectively replaced with a defective?
Well, again, it sounds like you didn't record any info about the phone in the first place. So it would be pretty much impossible to tell. I always record either the serial number, from settings, on my repair forms. Can never be too careful
If someone has IMEI and he wants to verify the board then where to match, from damaged board?
I could be wrong, but I'm pretty sure there isn't a serial number on the board, and without being able to boot it up, you wouldn't be able to tell the serial. Maybe if I comment on this, one of the other volunteers will have a better answer
댓글 달기
On the sim shield u can find serial no..
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Here is a little trick that i do when i repair a phone after you repair it just take a fine point magic marker
and put a mark on it only you know about and take a picture so if the customer comes back
you can know for sure if this is a phone you repaired or not mark the case and a small spot on the
mother board just don't make it obvious i put them on the edge of the mother board so its not easy
to see.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
And what happens if someone cleans the motherboard?
댓글 달기
Few days back. My I phone not working and I am goes to an local repair center, the local repair center repaired my phone but now my iphone does not pick my I cloud which I previously used. I also observed that after repair the mother board number was mismatched with my apple ID. please guide me what can do?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Antonio 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 24
전체 시간: 12,567
