The top screen of my ds is floppy
the top screen of my ds is floppy it as no resistance when closing and just swings open an slams shut
좋은 질문 입니까?
좋은 질문 입니까?
It sounds like the hinge is broken or weakened. Also, if the screen is flickering or malfunctioning it is usually cause by a damaged flex cable when the hinge gets broken.
There are 2 parts you will need, the top screen, which can be aquired via ebay etc. and you'll also need a replacement housing. If the hinge needs replacing you will actually only need one housing part, the inside topscreen part. The ds requires a triwing screwdriver to open.
The step by step replacement guide on here will show you how to do it.
해당 답변은 도움이 되었습니까?
There's a website for stuff like this :o
http://www.Nintendorepairs.com/
I have the same problem and I just found it although I have not used it yet :T
해당 답변은 도움이 되었습니까?
You can get the tri wing screwdriver that Lori mentioned at nintendo screwdriver.com
해당 답변은 도움이 되었습니까?
24 시간 전: 5
7일 전: 27
30일 전: 105
전체 시간: 8,994
댓글 1개
also the top screen flickers on to off and some times the images have a red hue or tint
Micheal 의
