주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mac Pro First Generation는 Apple Inc.이 제조한 Intel Xeon-기반 워크 스테이션 컴퓨터입니다. 2006년부터 2008년까지의 컴퓨터가 1 세대 모델에 포함됩니다.
No Power on Mac Pro
My Mac Pro will no longer power up.
It seems completely dead and will not
even show the power led when trying to power up.
I've tried a Reset holding the power for 5 secs
to reset the PMU but no joy.
Any help appreciated
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 4개
선택된 해법
Power Supply dead! Replaced and happy bunny again|!
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I take it you had the fans syncing software.
댓글 달기
가장 유용한 답변
According to which MacPro you have, there is probably a 3.6 volt AA Lithium battery. It looks like this: http://www.frys.com/product/2977135
I would replace that first. This is most likely a power supply issue and not a logic board issue. Here is a discussion on your problem: http://www.blograndom.com/blog/2007/11/c...
Do not replace the power supply unless you have the original system installation disks as they contain a program for syncing the fans. If the sync is not done the fans will run wild. If you can let us know about the battery and any symptoms at all it would help. There are specific tests for the lead out on the power supply and how much voltage each lead should have. If you want or need to go that far let me know.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Exc answer +
댓글 달기
Try a different power cord
try a different battery. If neither work suspect logic board. If one works suspect the other power connector (DC in or Battery)
If this answer is acceptable please return and mark it.
Good Luck,
N.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thanks, its a Desktop Mac Pro, are you suggesting the Pram Battery?
댓글 달기
Mayer i have a similar problem, i have the mac pro 1,1 quad 2.66. it kept crashing and then today it just died, no lights come on the logic board when i plug in the power cord, not even after u pressed the SMC reset or the one above. would that be all connected to a fried power supply or should try the battery??
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Please start a new question as other will not look at this one since it's been solved. thanks.
댓글 달기
답변을 추가하세요
Neil Sinclair 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 19
전체 시간: 14,699
