주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
질문 마감됨
Screen lifted from the phone
So my screen is lifting up from my phone a bit on the top. I was in school & I dropped it due to getting bumped over & it being knocked out of my hand onto the floor but, when I picked my phone up I took my case of to check on the phone & seen the screen lift then when I tried going on my phone it was difficult to use, I try swipe or push on my phone to use it and it doesn't really work, then it will either freeze or glitch while I try, I don't know what's wrong with it? I can barely use it. Also would I have to get a new screen if possible?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hey Aailyah,
It sounds like your digitizer is broken. This can either be solved by making sure the connector is all the way on or by simply replacing the screen. If you are comfortable repairing your own device there is a great teardown here on iFixit and you can order quality parts through eTech parts or iFixit's parts store. If you have any other questions feel free to ask or check out youtube.
Hope this helps!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 118
