주요 콘텐츠로 건너뛰기
A popular graphic calculator released by Texas Instruments in 1996.
12 질문 전체 보기
How to remove back cover?
I have a TI-83 graph calculator (not TI-83 plus), I think, by (c), it's from year 1996.
On the back cover I only see two screw (not 6 as I see here in another teardown). I have remove that 2 screw but can not remove the cover. How can I release the back cover, without broken it ? Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
At the bottom, by the data port, you can get a small screwdriver or plastic tool in the seam on both sides. Then just cautiously work your way around and toward the top; there are some snaps which will come loose.
I had the same issue with mine and got so frustrated that I just didn't care anymore if I broke it! It turns out that was the way to go.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
luisfiliperibeiro 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 29
전체 시간: 4,093
