주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and disassembly information for laptops manufactured by ASUS.
lost windows windows corruption
how can i restore windows
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
What version of Windows is it? How far does it get into boot? Do you know the cause of corruption?
Windows 10 I can't get pass utility screen
댓글 달기
답변 1개
선택된 해법
Get the appropriate windows disk for you OS then set your boot menu to boot from the optical drive . Once there select repair firs to see if your problem can be fixed that way if not then you will need to go to advanced and format the drive then reinstall windows. Make sure you have a valid oem key before starting . Hope this helps
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you I will have to get Windows disc and try this
댓글 달기
답변을 추가하세요
betty alston 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 83
