주요 콘텐츠로 건너뛰기
Support and repair information for laptops made by Samsung.
349 질문 전체 보기
all boot option option tried. press f4 for recovery
I would like to buy a second hand samsung series 9 laptop. But with error " all boot option tried.
Press f4 key to recover with factory image using recovery or any others key for next boot loop iteration."
My question is, with error like above, can i re-install the laptop with fresh windows 8?
If yes, how to do it?
Thank you.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 17
댓글 9개
good kee it u
I am also sick of this very very annoing thing which I have seen in GIGABYTE 4th gen non branded systems. if you have attached a usb storage whether it is a usb or external hdd..if you have shutdown ur pc the whenever U starts it ,it tries to boot from that usb which u forgottoen attached in usb port..then U lost ur perfectely running windows,,, why
even you cannot repair ur windows
shutdown or restarts, gigabyte mobo bios immediately tries to boot from last thing attached with pc..
any usb drive or even a harddrive (hot swapped)for any purpose u hv attached..
iN my case i am a shopkeeper , i recover data for my clients ..
Muchas gracias, era eso entre a la BIOS y cambie la configuración de arranque, guarde los cambios, reinició y excelente inicio Windows. Fue de mucha ayuda, saludos.
댓글 4개 더보기
댓글 달기
답변 10개
선택된 해법
Go to bios setting > boot> disabled secure boot>os made selection >cms and uefi os > save and exit Enjoy....
해당 답변은 도움이 되었습니까?
점수 87
댓글 91개:
Made an account just to say "Holy sh*t. That worked." Thanks for keeping it simple.
Thanks , changed some things and disconnected cmos batt , and this thing started... I knew that it was something in the BIOS
Just like the first commenter, I made an account just to say that this works beautifully. Thanks a lot!
Thanks to help me out from the problem
thanks a lot
댓글 86개 더보기
댓글 달기
yes you can provided that the HDD is not damaged ....
To use a Pendrive You will need a 4GB+ USB flash drive for this procedure. then create your bootable USB Disk for the windows Or a windows 8 DVD disk
Then Follow below:
Shut down the computer and reboot into the BIOS by pressing F2 repeatedly immediately after pressing the Power button. Under the "Advanced" tab, set Fast BIOS Mode to Disabled. Under the "Boot" tab, set Secure Boot to Disabled, then OS Mode Selection to CSM OS. Then select "Boot Device Priority" and move USB HDD to the top. and Save your settings then restart
The computer should restart and boot from your USB drive into the Windows installation. Go through the prompts and choose the custom installation option and when it asks where you want to install Windows, click "Drive options (advanced)" and delete all the partitions on the drive and create your desire
The installation will go through and then restart, remove the USB Drive and reinsert it when the Win Logo appeared (If you don't remove the USB disk, you will end up at the initial installation prompt again)
Once the installation is finished you can go to Samsung site and search your ur lap model missing drivers and download them.
TIPs:
reboot into the BIOS and set Fast BIOS Mode back to Enabled (but keep Secure Boot disabled and the OS Mode as CSM OS) and you're done!
해당 답변은 도움이 되었습니까?
점수 19
댓글 19개:
Answer number 2 is correct its help me to solve problem. Thanks a lot
question. how can I create a bootable USB Disk if my computer is crashed and wont move past the Samsung logo?
@sp you need to get another working PC and a windows ISO and this Universal-USB-Installer u can download that by google search
thx.that's right
Hi i have a prob with my samsung its runing windows 10 but when i turn it on it pops up with logo n then restarts to logo again then black screen saying all boot options are tryed press f4 if i press that it repeats the same thing but i can get into boot settings but have no idea what to do can you help please
댓글 14개 더보기
댓글 달기
SOLVED:
I had the same problem on my Samsung laptop after I cleaned out all the partitions and reinstalled windows from a USB. The process required legacy USB.
After a flawless install I couldn't boot from the HDD.
I found that I could boot the OS on the HDD by plugging in the bootable Win USB and ignoring the "press any key to boot from USB".
After booting into Win from the HDD, I repaired BCD using Visual BCD, a free program. If you cant boot into windows, you can still make the HDD bootable by manually editing the BCD entries.
Then I went into command prompt and converted MBR disk to GPT using MBR2GPT command. This command will work only if the disk is a system (bootable) disk.
Then I shut down windows, removed USB, set Fast BIOS to enabled and disk type to UEFI.
The problem was that I made a single partition on HDD manually and windows never made a EFI boot partition on the HDD.
Hope this helps
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
The previous answer on this post: "Go to bios setting > boot> disabled secure boot>os made selection >cms and uefi os > " solves it only temporarily for me.
After you keep using the laptop, after sometime, it kept going back to Secure Booth in the Bios. It might be for security reasons, I dont know. And then I had to go back to the bios to reapply the steps: Boot-> disabled boot, etc.
So I went into the Bios, change to disable secure boot, etc, and boot into my windows 10 machine.
I opened the cmd in administrator mode (provided that you booted to windows), and ran the command: MBR2GPT /convert /allowFullOS
This commands allows windows 10 to boot in secure mode. Now my machine is working fine again, with normal bios options.
댓글 달기
To fix this, you need to remove the bottom case of your laptop and adjust the removable hard drive part next to your laptop battery. It may need to be
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I had the same problem, was very annoying. I tried every solution one of them temporarily helped.
Finally I got enlightened and replaced the CMOS battery. Now everything is perfect.
(OMG same battery for 6 years)
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I had similar issue of exhusted boot options then my HDD was removed and replaced with brand new SSD. The windows was reinstalled on that new disk. Then to my surprise the message that was before on the old hdd is now showing every other start of my laptop which Samsung notebook 7 spin. The bios solution above didn't work. Would that imply that the new hard disk was not installed properly or what would be a once and for all solution. Would appreciate any lead. Thanks a lot.
댓글 달기
Hello,
I have the same problem.
My Samsung Ativ 9
Wont be able to go to Bios,
I repeatedly press F2 or f4
Nothing works.
It has this Loop Error,
I remove the SSd and it says
"All boot options are tried. Press f4...."
Then it shutdown
I cant go to the BIOS
I have Set Fast Boot
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
The Reason I remove the SSD
bec it has this AHCI Error.
It all started when i had to went to Bios and Change AHCI Mode to Enable, now it has this error I Cant Stop.
All I need is Set the Bios Back,
But I cant, I have set Fast Boot enabled. I have tried 10,000 times f2 or f4.. holding them, before powering on.
Please Help.
try pressing repeatedly the F2 whiles powering on. do not pres and hold. and i strongly advice you should try that with external usb keyboard if you are still having problem
@spangler you probably dont know what u are doing or u wanna take advantage of ppl. What do u mean by terminal. U are very funny!!!! Here is a community where ppl help ppl not take advantage of their problems
댓글 달기
i am also having the same problem all boot options are tried. press f4 key to recover with factory image i tried all the keys f4 i cannot boot into bios, and all this started when i changed booting order in BIOS, please help
해당 답변은 도움이 되었습니까?
점수 0
댓글 6개:
guys anybody who can fix this problem.. dont tell to press f2 i have done that for 3 weeks
checked the samsung website they just give me a pdf manual to press f2 again
i know what i did wrong all i need is to get back in BIOS and fix it..
Press and release f2 repeatedly and swiftly whiles (dont press and hold). Pressing the power buttom. It will take u to bios. Better still remove the hdd and try the procedure.
i tried that still not accessing bios
댓글 1개 더보기
댓글 달기
turn the safe boot off and switch the os to UEFI os if on windows 8 and above and also turn fast bios mode off.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I just fixed the same issue. I replaced the SATA cable that connects my hard drive to the motherboard and that was the issue. If you have this issue it may be a good place to check. Open up your laptop and see if the cable is damaged. Before you order the part make sure you have the right part number as I order the wrong one the first time. Once I got the part I installed it. Let me know if this helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I was able to get mine to boot a few times just by disconnecting and re-connecting the SATA cable. Good Luck.
댓글 달기
I have a Samsung galaxy book 2 and I got the same error as in BO tries now I'm in the Bios menu by pressing F to immediately after pushing the power button and I have a red orange blue and green square on the top left I'm assuming that that's the fast by us how would I get out of that to bios
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
charless 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 12
7일 전: 77
30일 전: 294
전체 시간: 168,367
