주요 콘텐츠로 건너뛰기
2015년 3월에 발표, 2015년 4월 10일에 출시된 Galaxy S6 Edge는 Samsung의 최신 주력 스마트폰 곡선형-스크린 버전입니다.
20 질문 전체 보기
What can I do after waiting 2 months from water damage?
I drenched my phone in the pool for like 5 seconds not even half way down the screen turned off. I tried drying at the moment by blowing into the charging port (side that was dry) and not knowing when I got home I tried charging it to see if it worked still. At the time it was doing what it is doing now just stuck on 0% battery and never moves up a percent. It is now 3 months since the incident what can I do to get it to work
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 3개
선택된 해법
Clean ever connection with a soft toothbrush. As well clean the logic board use a 99% isopropal alcohol for all cleaning. now is the time to start drying out the phone. Set the screen in a desiccant or silica gel leave it in for several day moving it from time to time to get the max effect from the desiccant . use a blow dryer on a low heat setting to dry the rest of the phone. replace the battery with a new one consider the old ones done. Clean again with isopropal alcohol let dry and when you think everything is clean and dry reassemble the phone (make sure to clean the contacts on the screen after removing from the desiccant). Once you've reassembled the phone its time to power it on. Hold your breath and hope for the best
이 답변이 도움이 되었나요?
점수 4
댓글 3개:
can you still try after 3 months past ?
@anahyy it never hurts to try . The phone will defiantly be dry by now it will probably be quit corroded I would completely remover the motherboard and soak it, remove any shields to access the board completely . definitely replace the battery
Can I fix water damage of an Huwaui P30 after 24 month's 'it goes on the immediately off..'
댓글 달기
If the screen turns on to display that your battery is empty, then the issue might be only a charging port issue.
I would replace the charging port, a replacement costs around 8 to 12$ on eBay and you can find guides on YouTube to replace it yourself or bring it in to a repair shop.
But given that it drowned it water other issues might come up even after fixing the charging port.. I would still give it a shot.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
I will definitely try that. The phone when plugged in either shows 0% or a Lightning sign inside a battery; when screen is off the red light on the top left is on as if it is charging but the screen has no signs of water damage. One time it was stuck on a loop of it powering on saying Samsung Galaxy S6 Edge. So should I still get the charging port replaced or is it done with?
Yeah I would then try what @jimfixer suggested first.
If you leave your phone plugged in, are you able to boot? or are you getting the loop every time? Plug your phone in a power outlet, not USB and try booting the phone (Preferably do this after cleaning out and drying out phone if issue persist).
댓글 달기
I'd say replace it, if you had an iPhone and have apple care then your taken care of. But if you don't or it's still not working, I suggest you to save and buy a new apple iPhone or phone, or being it to a professional place where they fix phones and listen to them for advice.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I have I samsung galaxy 8plus it drop in the toilet and I blow it out and it comes on but the next day it went blank this happens about 4 months now I leave but just now I try to charge it but the screen is blank but it vibrate to say it charging so I put it in some rice water is it possible that it will come on after couple days
bruh i've the same issue and idk what to do
댓글 달기
답변을 추가하세요
Jeffrey Arezalo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 6
전체 시간: 13,482
