주요 콘텐츠로 건너뛰기
2010년 중반기 모델 A1278 / 2.4 or 2.66 GHz Core 2 Duo 프로세서
794 질문 전체 보기
질문 마감됨
MacBook cannot recognize battery
When I followed the battery replacement guide on this site exactly, I booted up my MacBook to see that my battery had an x through it with the no battery availible popping up when I scrolled over it. I (stupidly) left the computer on while I browsed for a solution. The whole time my charger showed a green light. Suddenly the computer turned off and hasn't been able to be turned back on since (about 2 weeks) despite switching to another battery and another charger. The charger still shows a green light, which means the battery is either fully charged or installed incorrectly. I don't understand how it can be installed incorrectly when the only part to put it into the computer is the plug in. Please someone help me, I have no idea how to fix it and have made multiple forums on here asking for help, to no avail.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Was the X red or b lack?
The x was black
댓글 달기
답변 2개
가장 유용한 답변
If Brandons answer fails, read the Q & A: Black x in the battery charge symbol?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
You're going to need to run an SMC reset. Instructions can be found here
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Wait, sorry... I just missed part of that.
You're going to want to remove the battery, and start the machine with JUST the power cord connected. Sometimes if there is a battery issue, as a safety measure, the computer will not power up with the battery in place.
Once you get the machine to boot, follow the directions in the link provided in the answer I posted.
The machine doesn't start up, with or without the battery
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 101
