주요 콘텐츠로 건너뛰기
2.16 또는 2.33 GHz Core 2 Duo 프로세서
268 질문 전체 보기
질문 마감됨
Battery icon has black X tried everything
Hi,
I am currently using a early 2008 macbook running on OS X 10.6.8. I did buy it second hand and I knew there was a battery problem but i've decided to fix it but I am having trouble. The battery icon has the X symbol on it. I have bought a new battery and it's still got the X. I've tried the SMC and PRAM reboots and nothing has happened. I downloaded the 'Coconut Battery' app and it just says N/A on everything. The laptop runs with just the power cord plugged in but i'm sick of using it this way. The new battery when pressing the little button on it all the lights come up green, whilst the old battery nothing happens.
This is what it says on system profiler.
Battery Information:
Charge Information:
Charge remaining (mAh): 0
Fully charged: No
Charging: No
Full charge capacity (mAh): 0
Health Information:
Cycle count: 0
Battery Installed: No
Amperage (mA): 0
Voltage (mV): 0
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 10
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Automatic Restart On Power Loss: No
Wake On AC Change: No
Wake On Clamshell Open: Yes
Wake On LAN: No
Current Power Source: Yes
Display Sleep Uses Dim: Yes
Battery Power:
Display Sleep Timer (Minutes): 2
Reduce Brightness: Yes
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Wattage (W): 60
Revision: 0x0000
Family: 0x00ba
Serial Number: 0x0056c554
Charging: No
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Try reading over this Q & A and see if it helps: Black x in the battery charge symbol?
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I have. No help.
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 1,451
