주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
질문 마감됨
does not charge, does not show connection to I tune.
I fix the broken screen of I6 and put back together. worked great. I realize it was not charging keep on saying cable is not compatible. I tried this
hold the dismiss and unplug the charger and put back in. It showed charging sign but actually didn't charge. I noticed charging percentage was going down.
I connected it to computer and tried to upgrade the software, then it stuck in I tune showed the problem of -18 and later on 2001.
I have soft ware downloaded to get exit from i tune ( i phone care for Mac) and I tried to exit but it say no connection to the computer while there was connection. I got new cable from at&t store compatible with apple. again it did not help.
How to solve this. I have same problem with I 4s too.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
You might need a new charge port. Also try using a full original cable from the Apple Store.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I tried both , did not work.
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 5
전체 시간: 78
