주요 콘텐츠로 건너뛰기
Model A1320 / 8 or 16 GB capacity
156 질문 전체 보기
My iPod screen is turning white is this fixable?
the Ipod felt on the floor and when I plugged it in too my computer the screen turns white... everything is working only I can't see what is playing and i can't choose a number because the screen is always white. is this fixable by myself??
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
I noticed you never got an answer to this. Are you still having this problem?
댓글 달기
답변 2개
가장 유용한 답변
The iPod has a liquid crystal display. A very thin capsule with a chemical compound which builds up the picture under an electrical charge. Likely is this capsule ruptured as a result of the fall.
There will no longer be any picture or pattern. All you are seeing is the electroluminescent screen (backlight) which shines through the crystals in the display.
This must be replaced as a complete unit. Relatively easy on the 4th gen nano.
The contents of the display are regarded as toxic so take precautions if you see any of this inside. Mop up carefully with camera lens tissues.
After plugging in the replacement give it a quick try before pushing it all back into place.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
if i don't have a replacement for it can't i be give any other sol'n to solve this problem
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
sam 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 4
전체 시간: 2,025
