주요 콘텐츠로 건너뛰기
iPad 2세대, Wi-Fi, GSM 그리고 CDMA 모델이 있습니다. iPad 3 출시 전에 일부 모델을 새롭게 하였습니다. 수리는 어렵고 열과 비집기가 필요합니다.
730 질문 전체 보기
Ipad 2 black screen
My friends Ipad 2 was just displaying the empty battery symbol but would not charge or turn on so I put it into DFU mode when it was attached to the computer and itunes recognised it and started to download an update to restore the ipad, however when the update had finished downloading in itunes nothing happened and now the ipad just has a black screen it is not recognised by the computer or itunes and the button combinations don't do anything. I replaced the digitizer, battery and charging port as he dropped it in some water but after putting the new battery in it worked and it would charge but now it is dead. Does anyone know how to bring it back to life without having to replace the logic board as these are only available second hand and are quite expensive
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Possible water damage to the charging ic.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You need to inspect the motherboard, under any shields, and look for corrosion or damage to the board. You may be able to get it working by cleaning the board with alcohol and/or an ultrasonic cleaner. You may also need to replace some components on the board. Microscope will make inspecting the board easier.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Paul 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 163
