주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
질문 마감됨
Phone shuts off after back housing replacement
I recently replaced my back housing, and now my phone shuts off randomly. When it shuts off the screen turns whitish-gray with lines then goes back, and turns back on as if I rebooted it. The initial reboot appears(with the white screen and Apple sign). It stays on a little longer than one would usually expect. My phone stays on until I go into an app or play music then it shuts off and reboots again.
While replacing the new housing, I had to replace my battery. Could the battery I took from another iPhone 6 be defective. Please help, the constant shut off is annoying.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Yes most likely it's the battery. Try another battery and you should be fine. Also make sure you click the battery connector all the way in.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 66
