주요 콘텐츠로 건너뛰기
다섯 번째 Google Nexus 휴대폰. 2013년 10월 31일에 공식 발표되었으며 4.95” 1080p 스크린, 2.26GHz Snapdragon 프로세서 및 LTE 지원을 자랑합니다. Android 4.4.2, KITKAT. 제조사는 LG.
222 질문 전체 보기
My Nexus5 restarts every 5-10seconds - what's the problem?
My phone restarts every 5-10 seconds. I had this issue before and back then pressing the power button multiple times until the phone had fully booted fixed it. However, this now only helps to prolong the time until it reboots for a few seconds, but isn't a fix anymore. Is it a power button issue or a software issue? (The problem started (like the time before) right after the last software update)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 2개
가장 유용한 답변
Here are some troubleshooting tips
You can put your nexus in safe mode :)
Nexus 5 Troubleshooting
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I've had the endless boot animation problem before, it's hard to tell if an application's data is causing the issue, or an app itself. I don't believe there's a way to boot into Safe Mode from bootloader. I'm afraid your arguably easiest fix is to factory reset it and configure it again.
Sometimes when a Nexus is stuck in bootloop, I'll hold the POWER button down until the screen goes blank again, and without releasing the POWER button, hold VOL DOWN.[1] That may get you into bootloader. From there enter Recovery, and in Recovery you can factory reset it. It should boot normally and then take you through setup.
[1] Google's information for the Nexus 5 states that bootloader is reached with both VOL UP and VOL DOWN along with POWER, but my refurbished unit works with only VOL DOWN and POWER.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I've read since buying a Nexus 5 that there is a well known fault with the power button being faulty due to dirt build up. Rebooting every 5 seconds could indicate the power button being shorted, and acting like it's being held down continually.
You can pop the cover (see the tear-down guide) and clean it, or buy another. Obviously booting up and back into safe mode isn't possible if you can't even finish booting up due to incessant restart.
댓글 달기
귀하의 답변을 추가하세요
Ella 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 9
전체 시간: 1,536
