주요 콘텐츠로 건너뛰기
The Samsung SPH-M360 is flip-style cellular phone created by Samsung Electronics America Inc. It was released Oct. 31, 2010.
1 질문 전체 보기
Why will my phone not charge?
When I plug my phone in, the battery will not charge and the phone will not turn on, no matter how long I charge it. Occasionally, if the phone has been plugged in long enough, the screen will read "Charging Error".
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
It could be one of three problems. The first being a dirty charging port, if that's the case try cleaning it out with canned air or something similar to make sure you will have a solid connection between the charger and the port. The second problem could be a loose connection of the charging port to the logic board, if that's the case check the connection at the logic board and ensure its properly connected and fastened down. Lastly, it could be a bad logic board in which case you would need to get a replacement.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks..scoping a friend's old phone out for probs...
댓글 달기
I had a similar problem with my ZTE phone. Changing the charger solved the problem
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Hunter Parker 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 203
