Battery not Charging , Its now not powering on
My one plus two is not charging its now literally dead , i cant charge with any charger
좋은 질문 입니까?
좋은 질문 입니까?
1.If it won’t turn on then leave it plugged in for a couple of hours, and then hold down the Power button for a good 20 seconds to see if it comes back to life. OnePlus suggests that you try holding the Power button down for 20 seconds five times to power cycle the phone.
2.Try plugging it into your PC and see if it’s recognized or if it charges.
3.Try holding down Power and Volume down and see if it boots into recovery mode.
If nothing works, you may have to repair it.
해당 답변은 도움이 되었습니까?
The data cable works for data transfer (when there is charge in phone) but not it totally empty . Left it plugged for hours but nothing working .
It looks like your battery is damaged or otherwise faulty,maybe the best fix is to replace the battery itself. You can find repair guide for the battery replacement.
My data cable is not connected with PC it is only charging from PC. As well as my charger is not working.
Thank you so much. My OnePLus 3 went to a comma and i got a heart attack.
The 20 Sec power button hold worked for me
Thank you.
THANKS! a lot! hold down 5 times for 20 secs worked for me
I had the same problem a week ago. Battery stopped charging even after it was plugged in for hours. Took it to a service center which found that charging cable was faulty. Replaced with a new cable (Amkette Power Pro USB Type C) and now it charges surprisingly very fast - faster than it used to charge with original one plus 2 cable (red flat one)!
해당 답변은 도움이 되었습니까?
Hi! Did your phone accidentally turned off? Or it just stoped to take charge? I’ve been trying to charge mine with nexus 5x charger, but it didn’t help.
Too late to reply! In any case my phone never turned off accidentally. Due to faulty cable, phone charging was terribly slow.
Just do this.
Make sure phone is off
Try get into the recovery menu (power button and vol. down for a few seconds).
Then you need to wipe cache, reboot. Should be fixed.
해당 답변은 도움이 되었습니까?
it maybe concern to the USB charger board, it is easy damage during serveral time insert.
you can check detail for that or get a replacement for that to try.
Thanks
Jack.
해당 답변은 도움이 되었습니까?
I recently had the same problem where the OPT used to charge extremely slowly. One of the solution that worked for me :
1)Switch off the phone.
2)Press the power button and volume button simultaneously.
3)Now a screen will pop up.
4)Clear the cache memory.
5)Reboot the phone.
That's all. The charging improved a lot. Hopefully this will work for others as well.
해당 답변은 도움이 되었습니까?
There are various "answers" to this issue, and many of them sound suspiciously like voodoo. What is causing the issue with the battery / power? That might help. In my case, the phone went from intermittently starting, even letting me root the phone and use it for an hour or so, to gradually getting worse and worse as far as even starting at all went. At present it does not start.
Here are the more believable, from my point of view, possible reasons this is happening.
1. The battery has gone bad. (This may be in part true, but it is doubtful it went this fast.)
2. The charger and/or cable is bad. (I'm open to this, but have tested the charger on another phone. I don't have another usb c type device to test the cable on.)
3. The software is bad. (I tried two completely different operating systems, the default one and Lineage Oreo; both failed to continue running.)
4. The internal usb c ribbon assembly has gone bad / has a short in it. (I am considering buying a third party one of these off ebay - they are cheap and relatively easy to remove / replace - to find this out).
5. Some other short circuit / electronic issue is at fault.
If anyone else has this issue and sorts it down to a *cause*, I'd sure like to know about it.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 8
30일 전: 25
전체 시간: 42,546
댓글 4개
My one plus two mobile is taking more hours to charge.it taking 8 to 10 hours for full charge.what i would do????
anandraj9022 의
Im having the same problem. i even replaced the battery and still it turns on and switch offs immediately. please help
fathimath umaina 의
Lots of problem with battery of one plus two phone
Laxman 의
It says I need to turn my USB thing on to charge my phone where is that????
Eamon 의
