The HP Pavilion dv3, released April 2009, is part of HP's dv series. The dv3 may have various options for specific components, but comes standard with a 13.3 inch screen and weighs 5.5 pounds. The dv3 is easy to disassemble, due to its simplistic internal layout, and will most likely just require a screwdriver or two.
Get into the settings or control panel depending on which version of windows you have .Go to time and language and select language of choice . To help find what you need use google translate to help navigate the language its presently using. Hope this helps
댓글 1개
Whats the operating system?
Abdul Sattar 의
