주요 콘텐츠로 건너뛰기
2011년 하반기 모델, A1278 / 2.4 GHz i5 또는 2.8GHz i7 프로세서.
591 질문 전체 보기
Optical Bay replacement hard drive will not format or repair
Hello,
So I just installed two new hard drives into my macbook pro. The samsung 850 evo 500gb and a HGST Travelstar 1tb.
The SSD is in the original spot where my old hard drive was and is functioning properly.
Where I am having issues is trying to format the HDD in the optical bay slot. When I try to format the drive it fails and I have tried this several times!
If you need any details the HGST Travelstar is 2.5 inch 1tb 5400rpm SATA 6gb/s 8MB Cache
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
do you have a HDD usb reader ? it sounds like the adapter may not be compatible, what brand is it ?
댓글 달기
답변 3개
가장 유용한 답변
Put the HGST Travelstar in the original bay and see if you can work with it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
If it does work what would be my next step?
See if it is backward compatible to SATA II.
I do not think it was an I ordered a drive that is SATA II
댓글 달기
I found cheap CD bay drives can't by used like normal. Format it using a proper USB HDD caddy then reincert it in your machine. I would recommend using it as extra storage not a second o.s
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
From what Ive read it seems that it is unable to format it because the optical bay does not support SATA III
I'm sorry. I was trying to say remove the hard drive from the laptop and using a hard drive caddy. (A USB hard drive case) connect it to a USB on your computer and format it. Then once formatted you can put it back in the computer. And it should work fine. I used a 128gb ssd like this and I had to do the same thing
Just tried that I did not work.....
@H4CK3R - Be careful here! If the drive unable to format internally I would not assume it will be stable if I was able to format it externally and put back in. The issue here is the act of formatting and installing the OS is quite hard. This implies the drive is on the knifes edge, while it may appear to work to start with, any heavy use could bring the house of cards crashing down! This is a common trip up point people hit with drives that are unable to match systems SATA port speed.
댓글 달기
I had a similar experience when using a cheap caddy. Then I ordered something called OptiBay and now my drive formats/ repairs correctly.
I'm not promoting the product but it just works.
EDIT: Sorry to dig out this old thread but I was facing this issue and was following this topic since then. Once I resolved my issue I decided to post it here so that it can help someone who's wasting their time with this problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kai Nodera 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 511
