PowerBook G4 Aluminum 모델에는 여러 가지 유형이 있습니다.
886 질문 전체 보기
PowerBook G4 12" with 1.33 GHZ CPU . What model is this?
I want to try and replace the hard-drive myself.I ran the Apple hardware test and got Error code 2STF/1/4. The Logic board and Airport passed. Online, l got info that said this meant the hard drive is shot. Where do l start? I can't find any info, with this model's CPU speed of 1.33 GHZ. Apparently, Apple refers to this model as "PowerBook G4 12"/DVI" However, when l try and find a repair manual, l cannot find it for this CPU speed, only the 1.5 GHZ or lower. How important is the exact speed?
Is there something else that l should try first? The laptop cannot recognize the hard drive. I had to shut it down with the power button- then when l tried to re-install the software- it couldn't locate the drive.
l am a NOVICE please advice, other than outsourcing, because funds aren't there.
thanks
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
2개의 답변
선택된 해법
Hi, I am including a link to the file on how to identify your mac. Once identified follow the links to replace your hard drive. I believe you will find your computer is a Model A1010 and that you will need a IDE drive. Please get back to us if you need further assistance. Good luck Ralph
http://www.ifixit.com/Info/ID-your-Mac
If your computer is an A1010 this is the guide to replace the hard drive.
PowerBook G4 Aluminum 12" 1-1.5 GHz Hard Drive Replacement
해당 답변은 도움이 되었습니까?
점수 3
댓글:
+ good
의 답변
의견 추가하세요
Did you check the jumper switch on the drive? I had an iMac G3 that did almost the same thing, and it turned out that I set them completely wrong.
If you have the drive already in the laptop, then it doesn't really matter what the model is. But I'm trying to figure out what you mean by "model". 12" PowerBook G4 1.33 Ghz is your model...
Here's a page that talks about jumper cables/switches:
http://www.onlinecomputertips.com/hardwa...
해당 답변은 도움이 되었습니까?
점수 0
댓글:
usually the 2.5 drives do not require jumpers as they do not share a bus.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
mish 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,477
