screen shows everything double. What can I do?
i left my phone for a few minutes on the sofa and then when i come back the screen shows everything doubled.
좋은 질문 입니까?
좋은 질문 입니까?
Steps
1. power off button on the phone, press it
2. check the pop up on the screen (power off, restart, airplane mode, silent mode, VR mode)
3. Tap on the VR mode.
Bingo! problem solved.
해당 답변은 도움이 되었습니까?
very good answer and simple but very useful
This answer saved me.. thanks a lot
I dont have vr mode ,what to do,?
When you press switch off button... one extra message is displayed i.e. "VR Mode is ON".... just select that option... you will get back the original screen
해당 답변은 도움이 되었습니까?
Where is vr mode located
I freaked out when it happened but I turned it off. Then took the battery out and light pressed on the back where the battery sits. Put the battery back then turned it on then, it was fixed
해당 답변은 도움이 되었습니까?
You can't fix it with the apps or in the settings. You gotta repair it or simply just buy a new one🥲
해당 답변은 도움이 되었습니까?
24 시간 전: 8
7일 전: 41
30일 전: 200
전체 시간: 23,055
댓글 8개
I have the same problem for a LG Stylo 3 that was stepped on.
April Smith 의
did u fix it i got the same problem and same phone
Jing Jing 의
Swetha Thomas 의
no my phone fell on the groud
zyasiamorgan5 의
Does this drain my battery?
Nancy Yengel 의
댓글 3개 더보기
