주요 콘텐츠로 건너뛰기
Wheeled toy quadcopter contraption.
Why is my drone not flying?
It starts but won't take off?
It just flips over on the wheels and by itself it just dosent go up?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 13
댓글 8개
Mine has the same issue, its like the propellers are revered. It wont take off, it will only only push downward into the ground, its unusable!
I have the same issue
same issue anyone know why?
me too it just spins backwards all by itself when you take it off on the weels for a few seconds and i think it has to do with balanced weight but at the moment im still trying to figure out whats wrong
댓글 3개 더보기
댓글 달기
답변 12개
가장 유용한 답변
The proppellers are mounted in the wrong order. Switch left and right propellers front and back. Had the same problem. The drone was pushing down instead of moving up
http://blog.parrot.com/2014/07/24/how-to...
이 답변이 도움이 되었나요?
점수 6
댓글 4개:
Hi thanks God bless you it works i thought my new drone was spoilt i came here read your started my drone and it came i recommend this to everyone IT WORKS
hello, thank you your suggestion works
Thanks a ton! UDAMAN
Top man. It's working now :)
댓글 달기
Two propellers angle up and two angle down. Align then in a cross cross pattern so:
front left angle up - front right angle down
back left angle down - back right angle up
이 답변이 도움이 되었나요?
점수 4
댓글 3개:
Thank you so much. This is exactly right!
OMG this was helpful!!! Thank you!!!
Thanks it works perfectly
댓글 달기
Keep switching the propellers and trying it until you get the correct order
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
ok thank you
댓글 달기
But I figured it out one of your PROPELLERS might be WEAKER than the other ones allowing it to be UN-EVEN. For mines that's what it is but I might need to buy new propellers if you can do that
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
i bought new propellers it still doesn't work
댓글 달기
yes thats all it does and dont come off the grown just flips foward
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My drone typhoon h is not responding to the monitor
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My typhoon h drone camera is nor responding to the monitor
이 답변이 도움이 되었나요?
점수 0
댓글 달기
No.it goes on it's side. And doesn't fly. It's not mine. It's a friends drone I was using
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The wings are rotating but it doesnt fly
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had the same problem. I had to put the propellers on again after a crash and I just installed them on the wrong motor. Once in the right position it works like it’s supposed to. Good Luck!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Check the direction of the props. They might have gotten reversed and the 2 same angle props go diagonally to each other
이 답변이 도움이 되었나요?
점수 0
댓글 달기
if you press the takeoff button then try lifting up it should work
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
my parrot rolling spider never failed so theirs should be a priority
댓글 달기
답변을 추가하세요
Isaac Papasidero 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 11
지난 30일: 91
전체 시간: 18,355
