주요 콘텐츠로 건너뛰기
Model A1224 / Mid 2007 및 Early 2008 / 2, 2.4, 또는 2.66 GHz Core 2 Duo 프로세서
548 질문 전체 보기
Boot gets stuck on the gray screen before usual desktop appearance
Hi there,
my iMac suddenly stopped working (no cursor movement, no keyboard feedback, nothing), got stuck and I rebooted it manually.
After that, the boot process ends and gets stuck on a completely gray screen, after the startup sound, apple and loading bar.
I tried almost all software solutions (NVRAM reset, HD Recovery, incompatible .kext deletion).
The only way I'm able to boot the iMac is in SAFE MODE.
During summer I noticed some graphic glitches, that's why I believe the problem is hardware related and caused by GPU or something related to graphic.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Think about it. If it boots in Safe Mode, it's not a hardware issue.
UPDATE: 12-22-15
I looked at your link. They're guessing. Set up an external startup drive and install a clean system and boot from it. See if the problem persists.
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
After some readings I understood it's about advanced graphic drivers that Safe Mode doesn't use. Any fix for it?
What operating system are you running? Can you give a link to this reading?
Yes sure, for example this: http://apple.stackexchange.com/questions...
I'm running El Capitan.
Thanks
Did it do this with a lower operating system?
I have a similar situation except it starts only in recovery mode. I format the the original portion, instal EL Capitan again but same results. I tried to boot from external hard disk, but it didn't work either. Hard drive test in recovery mode showed a healthy OK hard drive. Not starting in single user mode, Not starting in diagnostic mode, not starting from external hard disk. What could it be? Thanks for any suggestions.
댓글 달기
귀하의 답변을 추가하세요
Luca 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 278
