Why and what is error message relating to
it started turning white during use and the disc drive has been unpredictable, I ran a hardware test on it and it is displaying error code: 4SNS/1/40000001:VDOR
좋은 질문 입니까?
좋은 질문 입니까?
The important part is the '4SNS', which would indicate a problem with a sensor on the logic board. You can try a system management management reset, and run the test again. Here's how from Apple: http://support.apple.com/kb/ht3964
If you still get the 4SNS failure, then the logic board will be the culprit.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,608
