주요 콘텐츠로 건너뛰기
2009년 6월 출시 / 2.53 GHz Core 2 Duo 프로세서
170 질문 전체 보기
How to check the hard disk cable?
I replaced the original Hitashi hard disk by the Seagate Momentus XT. I tried to clone my already working system with SuperDuper as well as Carbon Copy Cloner. With the both ways the system couldn't boot. A blinking folder icon with question mark was shown instead of the apple logo while booting.. blinking forever. However, I could boot it as external drive, connecting it via USB.. which is a sign that there is something wrong with the connection cable.
I have also tried doing a fresh installation, but also with no hope. The installation was always failed with an error message. However, the installation was completed successfully when I connect it as external.. which is a second sign. Also, I could boot it successfully via USB after the installation completed (still connected as external.) Once I connect it back as internal, the same booting problem happened again (blinking folder icon with question mark, forever.)
I have the feeling that the cable connecting the hard drive to the logic board has a problem. However, I don't want to pay for it before I make sure of that..
Any idea/suggestion is greatly appreciated.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Same here ,, plz help
Downgrading the EFI firmware from 1.7 to 1.6 solved my issue. As I remember, the downgrader that I had used with the instructions were posted in a long thread in MacRumors.com forums.
댓글 달기
답변 1개
선택된 답변
You may have cloned your old drive to a MS-DOS formatted drive or formatted non-GUID. In which case you could read it from an external. I would run disk utilities on it to check the format. If you do need to reformat be sure to set it to one partition and in the options select GUID.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
댓글 달기
귀하의 답변을 추가하세요
mamoundiraneyya 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 12
전체 시간: 2,167
