주요 콘텐츠로 건너뛰기
The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
Why is My Xbox showing Error Code 01?
My Xbox is flashing a red/green light and showing Error Code 01. Can you tell me what this means and how I can fix it? it is the original Xbox
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Hi louiserom70,
you might want to check this page for further information:
(e.g. What is the number of (red) lights that your ring of light shows? )
https://xbox-experts.com/errorcode/E01/0...
Regards and good luck/don't give up
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Thank you :)
hi again but it doesn't make any difference I mean still flashing red
Wow, you already replaced the MOSFETs and did a reflow of the CPU, HANA chip?
Please check again if this is the correct solution for your problem depending on the number of red lights blinking and the error code.
Maybe some else here has an alternative solution?
댓글 달기
Loose wire at one of the connectors.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
louiserom70 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 4
지난 30일: 15
전체 시간: 570
