주요 콘텐츠로 건너뛰기
The HP Photosmart Premium All-in-One printer can be used as a printer, copier, scanner. This printer uses a 5 color print system.
after loading new ink cartrides
After changing an ink cartridge I get a warning that the ink cartridge is missing , If I disturb outers then they are also listed as missing , this problem started a while ago & after playing with them I could get them to work quickly but its getting worse
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
I would check to make sure that the connections between the printer and the chip on the inks are clean.
Another thing could be the type of inks you use. Some printers are able to detect if you're using compatibles as opposed to originals.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Ron Nelson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 119
