주요 콘텐츠로 건너뛰기
2006 중반기/ 모델 번호 A1181 / 검정 또는 흰색 케이스 / 1.83 or 2.0 GHz Intel Core Duo 프로세서.
418 질문 전체 보기
Black MB won't boot
I have a black MB 2.16GHz from 2007.
When I switch it on I hear the CD drive partially engage, the fan comes on, but the screen remains black. This happens both with battery, and AC. I have to do a force shutdown by holding the power key. Usually after about 10 times of switching on/off I eventually get the apple boot screen, and then a further 10 times after I get the computer on. It takes approx 20mins to switch my computer on each time, and if the lid closes it will not wake from sleep. In these 20 or so attempts the computer progresses a little further through the boot process.
Because my computer still *sort of* works I didn't think this was a logicboard issue, but now I'm not sure.
I'm rather at my wits end! I've reset SMC, tried swapping out RAM, reset PRAM, tried diff batteries, booted from AC only, full battery, low battery, and still no improvement.
History-wise: I had an inexcusable tarmasalata spill 2 years ago, and replaced the keyboard with no issues. Over the past 2 years (although not recently) I have upgraded RAM and HD. I've lost the startup discs so unable to do a boot check.
I've read about similar incidents of boot problems before, but never one where the computer can be resurrected through repetitive on/off attempts.
Answers most gratefully accepted! Thanks for your time.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Ok good question. You have done all the basic steps i would have taken as well what I would do to further isolate the issue is hook the computer up to an external display and see if that gets a picture when the issue is occurring. If it gets a picture even when the internal display is not than you can rule out an issue with the video card. At this point either the issue would have to do with the display or the connection of the display to the logic board. Keep in mind this is just speculation on my part but hopefully it will give you something to work with.
Good luck,
Xen
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Sounds good. The OP might also want to check inside for corrosion from the spill. +
Many thanks both. I'll give this a go and keep you posted.
댓글 달기
귀하의 답변을 추가하세요
islaly 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 1,027
