주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
Battery percent does not increase
When I charge my Iphone 6S, the battery is charged but it does not show in the display.
If I shut the phone off and then restart it the percentage "jumps" to the right level.
How do I fix that (I have the latest IOS)
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Battery recall program:
https://www.apple.com/support/iphone6s-u...
이 답변이 도움이 되었나요?
점수 3
댓글 달기
가장 유용한 답변
There seem to be a lot of different opinions on how to solve this issue, some easier to try out than other.
First of all, go into settings and turn off "show battery in percentage", then reboot the phone, recharge it and turn on "show battery in percentage".
Some say you need to calibrate the battery. This is done by fully discharging the phone, to the point where it turns off by itself. Then charge the phone to 100% and then discharging the phone again, without tuning the phone off for the entire period. However, I am not sure about the effectiveness of this method, but it is easy to try.
You could try and restore the phone to factory settings, to see if this elleviates the issue.
Now onto hardware issues.
If none of the above fixes solves the issue, you need to replace the battery. As you have the phone open, you can check for missing components around the battery connector - epscially the FL11 shown here:
Last resort would be to change the dock/charging connector.
Hopefully one of the points above will help you solve the problem.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Nils Edlund 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 1,596
