주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 더 큰 Apple MacBook Air 노트북 입니다.
465 질문 전체 보기
My brother dropped a glass of wine, can I fix it?
My brother dropped a wine glass on it and in the Apple store they told me that to fix it I have to change the motherboard and the keyboard. They give me a 800 eur budget.
Is there a way to get the pieces for myself (where?) and fix it for myself??
Is there any tutorial??
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 2개
Did they take it apart and look at it? What was damaged on the mother board? Simple liquid damage type services may fix the current board, which is where the bulk of the cost is. Keyboard replacement is possible but a tedious pain in the butt. If I'm not mistaken the keyboard on this model is riveted to the frame but can be removed and the rivets replaced with screws. Either way you have to gut the entire machine.
yes they did, where could I buy a motherboard then?
댓글 달기
답변 4개
선택된 답변
You can get a logic board here, but inspect it yourself before buying anything: MacBook Air 13" (Mid 2013-Early 2014) 1.3 GHz Logic Board
MacBook Air 13" (Mid 2013-Early 2014) 1.3 GHz Logic Board 이미지
상품
$199.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
it says out of stock, but thank you
댓글 달기
i am in west Africa Ghana with similar problem how can i buy a logic board from the website,my country is not in the shipment list.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi Eric,
You can try buying the logic board here:
https://www.commandmacparts.com
Good luck!
댓글 달기
You can try www.powerbookmedic.com They're on the pricey side but have always been reliable.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi Victor,
Sorry about your spill and hopefully you can get it fixed soon. You can swap a new motherboard in if you follow the tutorial here on the website:
Link text
As mentioned by @krisfuqua, replacing the keyboard is going to be time consuming and a pain in the butt. You will have to take pretty much everything apart to get to the keyboard.
You can purchase the motherboard and keyboard parts here:
Your motherboard price will range from $347-$700 depending your macbook air 2013 model. International shipping will cost between $50~100.
I hope this helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Victor 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 147
