주요 콘텐츠로 건너뛰기
The second generation of the Ford Ranger, featuring a mild restyling and new engine sizing.
41 질문 전체 보기
My gas gauge on my ford ranger will not work
my gas gauge will not work but for about 10 percent of the time on my 1997 ford ranger
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
When my truck is off it reads the amount of fuel it has but when I turn it on it goes to E. What could it be?
댓글 달기
답변 4개
선택된 답변
Try this video to help you diagnose the problem: https://www.youtube.com/watch?v=QO9rfPeX...
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
가장 유용한 답변
The sender unit may well be the problem but you dont need to pull the bed to replace or repair it . just drop the tank. The sender unit has small connection barbs on it that may get corroded by ethanol based fuels if you clean the connectors this can help.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
It is the fuel sending unit you need to pull the bed off and replace it with a new one it will work perfectly then
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
really you want this guy to pull off the bed to change a sender unit
I would rather pull a bed than a tank any day. At least unbolt the bed and tilt it. Its only six bolts and it goes back on a !&&* of a lot easier than a tank.
Thanks guys I think il cut a door in bed and put hinges since older just in case for later but thanks
댓글 달기
Cut bed and have trap door for later since old truck
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
jesseosborne38 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 29
전체 시간: 11,834
