주요 콘텐츠로 건너뛰기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1697 질문 전체 보기
PS4 not powering on
This morning I downloaded update 3.15 then played for about 30 minutes, when suddenly my PS4 turned off by itself. I tried turning it back on, but the light won't turn on at all, so I can't even run it in safe mode. I tried turning it on with my controller plugged in and still nothing. There's no smoke or smells coming from the console. I made sure everything was plugged in as well. Any help is very much appreciated.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개:
I tried turning on safe-mode, but the console has no power whatsoever. I also tried cooling it in the freezer and no luck. Thanx for your help guys
댓글 달기
답변 2개
Ok what you going to do is when turing the ps on keep in the power button till you hear 2 beeps and that sould probably open in safe mode then plug in you remote *
Do not know if you tried that ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I had a similar issue with this during the first release of the PS4. After trying numerous things, it turned out that my COOLING FAN in the back had fried out and because my PS4 was on for so long, it ended up shorting the cooling fan and over heating the mother board of the PS4. I was forced to do a Manufacturing Warranty on it. Try holding the power button until you hear the 2 beeps like explained above, if that doesn't work, try placing the PS4 into your freezer for 5-10 minutes to cool the system down and then plug it back in and attempt a start up to see. Do not leave the device in the freezer for anything longer than 10 minutes. After it is removed from the freezer, wait approximately 4 minutes to warm up within room temperature and then try starting it up. (do not plug the device in until its warmed up a bit within room temp.)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
ajbramirez811 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 633
