주요 콘텐츠로 건너뛰기
Repair information and troubleshooting for the HP Compaq Presario C700. This is a budget laptop made in 2008 as part of the Compaq Presario series of notebook computers.
wont power up with power plugged to it
with the power cord plugged in the light around the plug doesnt come and the laptop doesnt come on
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 3개
가장 유용한 답변
ok..here it goes for the whole world..
The problem was that PQ1 was bad. Is located next to the PCN1 "where the power jack connects to the motherboard next to the memory". PQ1 is a P-Channel PowerTrench MOSFET P#: FDS6675BZ. you have to replaced it and the problem has to be solved.
one important thing is that if your not qualify to do this kind of job..you have to pay for somebody else to do it...
이 답변이 도움이 되었나요?
점수 2
댓글 달기
DC-Jack needs repair
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I have a C700 that had this same problem except it was the PQ2 chip. I tried to replace it without success. I had read others having luck just bypassing the chip with a jumper. I tried this and the laptop has been running fine now for a couple of months. I would recommend using the correct replacement if possible.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Kindly define that how and where to place jumper to bypass the chip.
댓글 달기
답변을 추가하세요
mike ward 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 11
전체 시간: 4,418
