My MacBook Pro will only start after a SMC reset.
Hi,
Can anybody help me?
My MBP will only start after a smc restart, i can restart him when he is on but when i turn him off he wil not start again. I've tryed everything but nothing works.
NVRAM-reset, hardware test a complete clean install. System check.
Battery looks fine:
Informatie batterij:
- Serienummer: W031642YHD3LC
- Fabrikant: SMP
- Apparaatnaam: bq20z451
- Pack Lot Code: 0
- PCB Lot Code: 0
- Firmwareversie: 201
- Hardwarerevisie: 000a
- Celrevisie: 165
Ladingsinformatie:
- Resterende lading (mAh): 5144
- Volledig opgeladen: Ja
- Bezig met opladen: Nee
- Volledige laadcapaciteit (mAh): 5144
Statusinformatie:
- Aantal cycli: 107
- Conditie: Normaal
Batterij geïnstalleerd: Ja
Ampèrage (mA): 0
Voltage (mV): 125
English:
Battery Information:
- Serial Number: W031642YHD3LC
- Manufacturer: SMP
- Device Name: bq20z451
- Pack Lot Code: 0
- PCB Lot Code: 0
- Firmware Version: 201
- Hardware Revisio: 000a
- Cell Revision: 165
Charge Information:
- Charge Remaining (may): 5144
- Fully Charged: Yes
- Charging: No
- Full Charge Capacity (may): 5144
Health Information:
- Cycle Count: 107
- Condition: Normal
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 125
Update (01/16/2016)
Nothing got wet, it started after i replaced my ssd, he works perfect just won't start after i shut him off. Restart also works.
좋은 질문 입니까?
댓글 6개
Just looking at the battery info you have provided here its not the battery.
Dan 의
Did you get your system wet at some point or do something else to it that might be a factor? How about checking the thermal sensors to see if the system is over heating. Download this app: TG Pro paste a screenshot of the output for us to see in your question.
Dan 의
Who's SSD did you put in (Make & Model)? And did you add it Vs swapping out the HD?
Dan 의
I put in a Samsung 850 Pro 512GB but first cloned him with Superduper! My old SSD was a Kingston HyperX 240 GB
Peter Scholten 의
helo, I have the exact same problem with a Macbook Air 2015
did you find a solution?
thank you
Matthias
matthias 의
댓글 1개 더보기
